Door drafter
Andrew boiler
Member Posts: 44
Will a door drafter for under my door keep heat in my master bedroom?
Not sure what a "door drafter" is
but, if you are having temp issues and the master needs a bit more ummph I would suggest you look at a Tjernlund Airshare. It is a transfer fan that has worked well.0 -
Yes
Yes they work great. It will fix your t-stat as well"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
door draft dodger
The door draft dodger works great thank you.
Will it keep the heat in my bed room?0 -
Cold air
I just got door draft dodger it still seems to be cold should I turn up the heat?
Or how long will it take to use door draft dodger?
Any ideas?0 -
thank you
that was the best0
- 50 Industry Classes
