Thermostat Wiring
Member Posts: 4,642
For heating, we always connect wires to RH and W to call for heat. Until now, I never realized that if you connect a neutral wire from the transformer to terminal C on the thermostat, it will power the thermostat and you don't need to change the batteries.
Most of you will say "Duh", but I just never knew that.
Only if
you have that 3rd wire . Around here no one runs that extra wire ! And a big callback problem is dead batteries ........0
