Thermostat help
Hi I just got power back 1 this morning and my thermostat says it's 69 I have it set at 68 it's very cold I don't want it to turn it up please help me
  • Gordy
    Gordy Member Posts: 9,546
    Hmmm
    How long was the power off?
    What type of heating? Hot water? Steam?
    Do you have Radiators? Or radiant Heat?
    Was 69 comfortable before, and always your t stat setting?
    Jamie Hall Member Posts: 26,960
    And an obvious question...
    is the boiler running?  Does it run if you turn up the thermostat?
    If not, what was the power problem?  Is there a manual reset required on the boiler?  Did it lock out for some reason (if oil, did the burner lose prime, for instance?).  Was there a surge along with the power outage?  If there was, did it fry something?
