Logimatic R2107 Help Needed
zooba72
Member Posts: 25
Hello Everyone,
I need some help with my Buderus Logimatic R2107 configuration. I’m running a Burderus G215-4 boiler (OIL) and
have 3 zones in the house. Zone 1 is the
main living area (upstairs & downstairs), Zone 2 is the basement, and Zone
3 is the domestic hot water supply. I’m
trying to set Zone 2 (Basement) to a temperature around 50 degrees for both day
and night (50 day / 51 night). However
when I try to hold down the Heating Zone key to select the basement zone, I
only have one circuit and DHW. Can
someone please explain what I need to do in order to modify the temperature of
the basement zone? I ended up heating a
gutted basement last winter and it cost a fortune. The manual makes reference to module FM241 … Do
I need to purchase another module to modify the basement zone? I have thermostats in both zones, but the
Logimatic is controlling everything.
Please help! Thank you.
I apologize if this topic has been covered before, I couldn't find it in the forums.
can you increase decrease daytime and nighttime temps?
First off are you able to adjust any of you zones current temperatures Ex: Zone 1 adjust day temp to X degrees?
If you can adjust the daytime and night time temps switching zones should be fairly easy.0
- 117 Geothermal
