Where do you do it
i am installing a slant fin 30 steam boiler and was wondering the best place to put the make up water feed. Should it be above or below the normal water line?
  • JStar
    JStar Member Posts: 2,752
    Water feed
    Always below the water line. I prefer to feed water into the wet return.
  • Ron Jr._3
    Ron Jr._3 Member Posts: 605
    Jstar is right
    Most specs call for the feed to be piped into the return . I've been piping them into the boiler itself ( lowest tapping in the boiler ) with no problems at all too . I like to pipe it so the fill valve or auto feeder are close to the sight glass
