Help
hairball
hairball Member Posts: 19
Can some one look at the wiring diagram for a Calin Ez burn and help me out. My question is about the one wire that is black and red and the black wire . The black wire is for call for heat and must be of the same power source as the black and red wire that has constant power. Can I just put the one wire from the aqustate  to the red and black wire and the other wire from the aqustate to the black wire? Please help with this I got to make sure its right. Don't know how to post a pdf so if you can please look it up on the Calin web site that would be great.
Thanks
Chris
  • Aaron_in_Maine
    Aaron_in_Maine Member Posts: 315
    Wires
    The black is your b1 wire from aqua stat. The red/black wire needs to come from L1 on aqua stat so it has power for post purge.
  • hairball
    Confused
    Going to need more detail. It look like the black and red wire is constant power for L1 but not from aquastate
  • R Mannino
    R Mannino Member Posts: 443
    That Makes Sense
    Aaron, so black is hot and black/red is limit. Something has to turn the burner off.
  • Aaron_in_Maine
    Correct
    Yes the red black wire is for post purge. I usually power it from
    L1 on the aqua stat so when b1 drops out it still has power for post purge.
  • hairball
    help
    Thats ez burn GAS burner
  • hairball
    Gas burner
    Please look at the diagram on carlins web site
  • hairball
    diagram
    see what I mean
