Help
hairball
Member Posts: 19
Can some one look at the wiring diagram for a Calin Ez burn and help me out. My question is about the one wire that is black and red and the black wire . The black wire is for call for heat and must be of the same power source as the black and red wire that has constant power. Can I just put the one wire from the aqustate to the red and black wire and the other wire from the aqustate to the black wire? Please help with this I got to make sure its right. Don't know how to post a pdf so if you can please look it up on the Calin web site that would be great.
Chris
Chris
Wires
The black is your b1 wire from aqua stat. The red/black wire needs to come from L1 on aqua stat so it has power for post purge.There was an error rendering this rich post.
Confused
Going to need more detail. It look like the black and red wire is constant power for L1 but not from aquastate0 -
That Makes Sense
Aaron, so black is hot and black/red is limit. Something has to turn the burner off.0 -
Correct
Yes the red black wire is for post purge. I usually power it from
L1 on the aqua stat so when b1 drops out it still has power for post purge.There was an error rendering this rich post.
help
Thats ez burn GAS burner0 -
Gas burner
Please look at the diagram on carlins web site0 -
diagram
see what I mean0
- 129 Chimneys & Flues
- 122 Geothermal
