need some input on my shop heat
damar2003
Member Posts: 1
Hello, I am in the process of connecting a zone on my EFM 520 boiler for my shop. I have a brand new Reznor 23/33 unit heater which I know is not big enough to heat my 24x32 with 10ft ceiling shop, but my question is can I run my heat through the Reznor first and then hit a large cast iron radiator and still get good heat from the radiator. I appreciate any input.
More
Which reznor?
How big is the boiler?
What else is connected to the boiler?
Have you done a heat loss?
How big is the radiator?
Is there a reason to pipe in series?
You can do what you are describing, It is impossible to tell if it will work without some details."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 999 Plumbing
- 391 Solar
- 55 Water Quality
- 45 Industry Classes
