Buderus Logamatic worth it on new gas boiler? Compare vs programmable thermostats?
WWood_
WWood_ Member Posts: 5
Plumber plans on installing a Buderus gas-fired boiler to heat the 3 zone baseboard, ~1,400 sq ft part of our house as well as fire an indirect 50 gallon hot water tank.
We have programmable thermostats in each zone that have a M-F and weekend cycle with 3 separate time frames for each day (morning, day, night).   We use them to keep temps low overnight and during the day while we're gone and to come on morning, nights & weekends.
Would a Buderus logamatic be worth getting to further refine the system?  Or will the savings not be worth the cost, especially considering the conversion to gas (much cheaper bill than oil, 10% savings is much lower dollars saved) and the programmable thermostats.
Thanks,
  • Bob Bona_4
    absolutely
    The logo will give you outdoor reset, priority recovery for the indirect, pump exercise in off months and a host of other features. Pays for itself with the odr alone..
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,584
    GC124
    The Buderus GC124 comes with an AquaSmart control that takes a low cost wireless ODR module,doesn't have all the functions of the 2107 but does ODR real cheap and easy!
  • R Mannino
    R Mannino Member Posts: 441
    What
    is the price of comfort worth?
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    Zone setbacks
    If you are going to do short term setbacks (with their questionable efficiencies), you better have the boiler's own control do it, as with the ODR, the water temperature may be reduced in milder weather, and therefore slower to respond to temperature settings.--NBC
