Service
Haynels
Haynels Member Posts: 1
Question how is a reverse return used in a hot water boiler system?
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    Parallel reverse return
    Do a search here for that term, and you will find better descriptions than mine.
    In a nut shell, it is a piping layout which arranges the supply and retun to and from every radiator to be the same length/resistance so one close radiator is not favored over the one at the end of the line
