Service
Haynels
Member Posts: 1
Question how is a reverse return used in a hot water boiler system?
Parallel reverse return
Do a search here for that term, and you will find better descriptions than mine.
In a nut shell, it is a piping layout which arranges the supply and retun to and from every radiator to be the same length/resistance so one close radiator is not favored over the one at the end of the line0
