Which Pipe Sealant?
Bob421
Bob421 Member Posts: 5
I am curious which pipe sealant plumbers on this forum prefer when plumbing black iron pipe for use with natural gas,
Thanks, Bob
  • Rich_49
    Rich_49 Member Posts: 2,785
    Black Iron
    Permabond   LH050
    732-751-1560
    Rich McGrath 732-581-3833
  • Bob421
    Interesting
    write up on Google search. It states that it will even seal a joint which is not fully seated due to positioning. I will have to check my local plumbing supply houses. Thanks for the reply Rich.
  • SWEI
    SWEI Member Posts: 7,348
    I'm learning
    Anaerobic sealants are pretty amazing things.
    Lots of manufacturers, but not really common here other than industrial and fire sprinkler applications.
  • jonny88
    jonny88 Member Posts: 1,139
    dope
    Hercules pro dope.this is my choice for years.
  • MikeL_2
    MikeL_2 Member Posts: 543
    teflon tape +
    Teflon tape & Megaloc for us........
  • bob young
    bob young Member Posts: 2,177
    pipe joint compound
    we use rectorseal, permatex or blue block to name a few favorites
  • ChrisJ
    ChrisJ Member Posts: 17,336
    Not a pro
    But I used Hercules Megaloc on all of my gas piping and it worked well.  I didn't use any tape as it seemed to be frowned upon.  So far that is the only dope I've found that I really like.
  • icesailor
    icesailor Member Posts: 7,260
    Pipe sealant:
    Teflon Tape on everything. Now, only the Blue Monster stuff in the 1/2" x 1429" rolls. You don't loose them as easily. Rectorseal #5 on gas or any of the other kinds that you can't get off your tools or clothes or Rectorseal #100 with Virgin Teflon or MegLoc on potable water. Almost 100% leak proof.
    Heat is Teflon Tape with usually Rectorseal #5.
    PROPERLY APPLIED Tape!!!!!
  • CTheat
    CTheat Member Posts: 5
    Pipe dope
    Rectorseal true blue. On copper male or female adapters i use blue monster teflon as well
  • SWEI
    I'll ask again
    Does anyone make 3/8" wide Teflon tape?  I'd love to have it for the small stuff.
  • kevin_58
    kevin_58 Member Posts: 61
    teflon tape
    I dont know about 3/8but they do make 1/4 in. I think markal makes it, its been a while since i had some. Now that you made me think about it i think i will order a few rolls.
  • SWEI
    Markal 434-44081
    thanks!
