5" drop header
gcp13
gcp13 Member Posts: 122
Out with the old in with the new
Peerless boiler with 5" drop header
3" takeoffs
Separated the mains 2 1/2 in gate valves
Hoffmann 75's at each end
  • JStar
    JStar Member Posts: 2,752
    Header
    I like it!
    What size is the boiler? I really like the look of the bushings instead of reducers on the drops.
  • Dave in QCA
    Dave in QCA Member Posts: 1,803
    excellent
    Beautiful install!!
    Dave in Quad Cities, America
    http://grandviewdavenport.com
  • Rod
    Rod Posts: 2,067
    5 " Dropheader
    Very Nice!
  • gcp13
    edited September 2013
    64-08
    thanks, such helpful info on this site
    peerless 64-08 399,000 btu
    cant wait to fire it up,couldnt find any reducing 5' fittings
    so i used bushings ,but now i like it.
    no fun dropping the old 4" o.s & y from ceiling
    Steamhead Member Posts: 17,768
    Looks good
    but are those Hoffman #75 vents adequate? Those 2-1/2" mains would have to be rather short for the #75s to vent them quickly......
    Consulting
  • gcp13
    Main vents
    No not even close, but had to talk customer into
    Adding these two
    After they see results we can add more
    Probably three Gordon's # 2 on each end
