5" drop header
Header
I like it!
What size is the boiler? I really like the look of the bushings instead of reducers on the drops.0 -
excellent
Beautiful install!!Dave in Quad Cities, America
http://grandviewdavenport.com0 -
5 " Dropheader
Very Nice!0 -
64-08
thanks, such helpful info on this site
peerless 64-08 399,000 btu
cant wait to fire it up,couldnt find any reducing 5' fittings
so i used bushings ,but now i like it.
no fun dropping the old 4" o.s & y from ceiling0 -
Looks good
but are those Hoffman #75 vents adequate? Those 2-1/2" mains would have to be rather short for the #75s to vent them quickly......All Steamed Up, Inc.
Consulting0 -
Main vents
No not even close, but had to talk customer into
Adding these two
After they see results we can add more
Probably three Gordon's # 2 on each end0
- 116 Geothermal
- 169 Indoor-Air Quality
