Drop header going in
ALIGA
Member Posts: 194
boiler replaced about a year ago, drop header being installed.
please let me know if you see anything off. thank you.
dropheader vs non
Does anyone know what the breakeven point is for a dropheader vs non. I know there are alot of variables, just trying to figure out if the expense is justified.
Dropheader piping and fittings so far add up to $800.0 -
"Standard" Header vs Dropheader
Hi- In comparing a properly sized “standard” header to a drop header you first must consider that the piping sizes used should be the same as those used on a dropheader so therefore the costs will be pretty much the same on these items. The differences are:
On the installation:
The material side - it is the added cost of just a couple of extra elbows and pipe nipples.
The labor side- it saves time as the risers are much easier and forgiving to attach to the header pipe using a dropheader configuration. Depending on the difficulty of the individual job, I tend to think that the extra material cost comes pretty close to being balanced out by the labor savings from the ease of installation. (There can also be a saving from not having to repair the hole in the basement drywall where your wrench impacted after being thrown by you when you got frustrated trying to get a “standard” header's fittings joined together
Long range benefits of a dropheader over a "standard" header-
- drier steam means better efficiency
- less thermal expansion stress on the boiler sections
- easier to adapt to a new boiler if one is likely needed in the near future
Your piping looks pretty good and should be more efficient than what you previously had.
- Rod0 -
feedback
Thank you Rod.
Some of the main concerns were addressed:
- eliminating bull tee
- fixing the slope to the two mains at the bull tee
- removing the 2" pipe from old header
- raising the risers
- utilizing both boiler tappings0 -
Drop header installation
If you could increase the header size by 1 size, you would slow down the steam even more. As shown, the 2 boiler risers appear to feed a header of the same size, so the steam would speed up a bit in the header. As seen, it will still be an improvement over one boiler riser, and no drop header!--NBC0 -
TSP time
got my hands on some real TSP. will be cooking and skimming this weekend.0
