Steam Orifices
GUYS
I have a job where they are converting a church BACK to a vapor steam system. The engineer is asking for orifice plates for each radiator. Are these commercially available anywhere or must they be fabricated out of sheet metal.
Prisco
  • JUGHNE
    JUGHNE Member Posts: 11,513
    edited September 2013
    Check over on the steam side of the wall--oriffices
    You could look at the thread called "1930's VECO vapor system..." and ask what chart is used for orifice sizing??  Thanks...actually impressed that an engineer would take the simple approach.
    Jamie Hall Member Posts: 26,837
    The very short answer is yes
    as I recall Tunstall...
  • Rod
    Rod Posts: 2,067
    Tunstall
    As Jamie mentioned, Tunstall are the people you want to contact about orifices. They have orifice plates and will help you select the right sizes. Good people to work with.
    Here's their contact info:
    Tunstall Corporation
    118 Exchange Street
    Chicopee, MA 01013
    Toll Free: (800) 423-5578
    Phone: (413) 594-8695
    Fax: (413) 598-8109
    http://www.tunstall-inc.com/
