HTP Elite ???
StefK
Member Posts: 8
in Gas Heating
Does anyone have any thoughts on how the HTP Elite compares to the Buderus 142 or any of the other similar models ..Thanks
Elite FT
The elite and elite plus have a Giavonni heat exchanger. It is stainless and a very common exchanger found in many condensing boilers. I. would get the Elite FT. It has the same exchanger that Triangle tube and lochinvar are using.
I like all stainless designs better than aluminum.
Albert Einstein0 -
Thanks
Thanks for the feedback...0
