Zone actuators & zone valves
BenWoj
BenWoj Member Posts: 33
I can't seem to picture this in my head. I'm trying to determine if I can use one manifold to supply heat to two zones. I was currently going to buy two 4 loop manifolds and power each one with their own zone valve, but if I'm able to purchase one eight loop manifold how would I hook up the zone valve with manifold actuators?
  • Rich_49
    Rich_49 Member Posts: 2,785
    Actuators
    in effect are zone valves for each loop . You would not need additional zone valves .
    732-751-1560
    Rich McGrath 732-581-3833
  • Zman
    Zman Member Posts: 7,611
    As Rich said....
    You would have an actuator on each loop. That  would be 8 actuators and a big enough transformer to power them all.
    You would be better off going with 2 zone valves and 2 regular 4 hole manifolds.
    Carl
    Albert Einstein
  • BenWoj
    edited September 2013
    That's what I was thinking
    When does it make sense to use manifold actuators?
  • Rich_49
    When
    you have multiple zones in an area where only 1 manifold is desirable or possible .
    732-751-1560
