diverter tee?
james barnett
Member Posts: 8
So I got into an argument with my installer, who is kind of young... We are installing radiator hot water heat on a two story house, there's an upper floor manifold, and a lower floor manifold, a tstat on each floor operating the circulator on each manifold. I like to keep the heating system as simple as possible. All the radiators are plumbed home run, except one, and that's in a long room where we have two radiators that will share a loop. My installer wants to plumb these two radiators in series. I want to plumb them two pipe reverse return with a diverter tee. He says we won't be able to balance the manifolds properly doing it this way because there will be too much resistance introduced by the diverter tee, and we'll have to dial down all the other loops. I can't see why this would be the case, seems like roughly the same resistance either way, and my way both radiators get equally hot water.... Who's right, or more likely, why are we both wrong?
Diverter?
Why not just pipe them reverse return? I don't understand the need for the diverter.
Albert Einstein0 -
series will work
reverse return is better. Diverter tee is not used.Cost is what you spend , value is what you get.
cell # 413-841-6726
thanks guys
thanks Carl and Charles. No diverter tee. Just reverse return.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 999 Plumbing
- 391 Solar
- 55 Water Quality
- 45 Industry Classes
