ID this item.
Chuck_17
Member Posts: 148
Located in a school with a two pipe steam system (vacuum). There are more than one. I am sure I have seen it before (and probably knew what it is at some point).
if you can get me
the info written on it i may be able to locate its patent for you.gwgillplumbingandheating.com
Steam
Where is it attached to the system?0 -
Outside Wall
It is on the inside of an exterior wall. There at least two in the relatively small school.0 -
It looks like
a diaphragm.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Piping Size?
What size is the piping into the device?0
- 167 Indoor-Air Quality
