Small 3/8" PEX manifolds
SWEI
Member Posts: 7,348
Working another small, tight house and wondering if anyone makes PEX manifolds in smaller sizes. I'm looking at a bunch of 3-4 port manifolds for 3/8" tubing which will be fed with 1/2" PEX and everything I have used in the past is suddenly looking oversized...
If
head losses aren't too high go with it . It is what it is . I would be careful of velocity noise though , you know what is right .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
3/8" is the best answer for this
but I just don't see that many manifold options. Viega Minibloc is one.
http://www.blueridgecompany.com/radiant/hydronic/471/rht-mini-manifold is another - not sure who actually makes those but the sizing looks about right.0 -
How bout...
Watts? I thought I remember the manifold that takes a 3/8 or 1/2 pex, depending on the compression rings/adapters.There was an error rendering this rich post.
copper manifolds
from Watts Radiant, Alberta T-Drill, Sioux ChiefBob "hot rod" Rohr
