flow conversion formula
Pumpguy
Member Posts: 778
Does anyone know an easy formula I can use to convert pounds per hour of dry air at sea level to cubic feet per minute?
Thanks
Thanks
flow
I'm a flunked out retired fitter not an engineer. My take is standard air as defined by ASHRAE is air at 29.92 in. Hg , 69ºF and dry has a density of .075 Lbs./Cu.Ft. so if you divide your Lbs./Hr. by 60 you will have Lbs./Min. divide that by .075 and you will have
Cu. Ft./Min.There was an error rendering this rich post.
Brilliant!
I'm gonna try that. ThanksDennis Pataki. Former Service Manager and Heating Pump Product Manager for Nash Engineering Company. Phone: 1-888 853 9963
The first step in solving any problem is TO IDENTIFY THE PROBLEM.0
