flow conversion formula
Pumpguy
Pumpguy Member Posts: 776
Does anyone know an easy formula I can use to convert pounds per hour of dry air at sea level to cubic feet per minute?
  • bob_46
    bob_46 Member Posts: 813
    flow
    I'm a flunked out retired fitter not an engineer. My take is standard air as defined by ASHRAE is air at 29.92 in. Hg , 69ºF and dry has a density of .075 Lbs./Cu.Ft. so if you divide your Lbs./Hr. by 60 you will have Lbs./Min. divide that by .075 and you will have
    Cu. Ft./Min.
  • Pumpguy
    Brilliant!
    I'm gonna try that.  Thanks
