hot water boiler
Paul S_3
Member Posts: 1,291
Is there any problem with piping a hot water boiler with a black steel header and connecting zones with copper?
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
347-692-4777
ASMHVACNYC.COM
Not a problem.
You are talking about a closed loop hydronic boiler? Not dhw?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
closed
its a closed loop hydronic systemASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
BOILER
SOUNDS CORRECT. POST PHOTO SO WE CAN CHECK PIPING ARRANGEMENT. DO YOU HAVE FLOW CONTROP PROVISION ?0
