Changing flooring in existing radiant setup.
sgtmikey
Member Posts: 14
We are considering replacing the wood flooring in one area of our home with tile. The room is an extension on the back of a cape: a kitchen, dining, living room. It is a single zone, 3 loop, sandwich install with aluminum plates. 3/4" qs oak covers it now. We were thinking of going with tile laid on 1/2" backer board.
The attached image shows the floor specs. It is room 1.
How will this change effect heat loss, or any other aspect of heating? I am in the early stages of a gas conversion. Thanks.
Sgt Mikey
as long as these rooms are presently on the same zone and you are satisfied with the comfort and all are to be changed keeping similar characteristics you will be fine . Your system for these rooms will be a bit more responsive . You are not changing the Finish floor R value negatively so all should be good .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
It Doesn't Change The Heat Loss
It changes the required water temp needed to overcome the heat loss based on the R-value of the finished floor. Tile has an R-Value of .5, 3/4" oak .68, There will be no effect or such minimal effect that you would then balance off at the manifold.There was an error rendering this rich post.
Chris's
statement is correct . However when dealing with any heating occupant comfort is key . If the floor surface temp should be uncomfortable (doubt it though) the loop/loops for the kitchen area can be separated at the manifold by adding actuators and a thermostat in kitchen . Not a terrible remedy , but not worth doing before determining if in fact there is a comfort issue .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
- 49 Industry Classes
