skimming T installation
hounddog
Member Posts: 1
Greetings; I am installling a new Utica steam boiler with two taps; Sorry for the simplicity of the question. Can the skimming T be installed on either the left or right tap?
Thank you!
Thank you!
skim tapping
your choice0 -
Before installing
look inside the casting and make sure the bottom of the tee is above the bottom of the section nipples. I know it is not on Dunkirks and it may not be on yours. If it isn't,you need to use a bush or reducing tee to move it up so you can skim all the sections. This is one of those places where the manufacturer's directions are often wrong.There was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
