carlyle o6e compressor failure
elfie
Member Posts: 266
diagnosis for a compressor that needs replacing is that it was mechanically broken up internally. compressor while still operational was vibrating excessively. the oil pressure switch had been disconnected.
question is, what lead to compressor failure.
if oil pressure switch had been connected could it have protected the compressor? would oil pressure switch being disconnected contribute to a compressor failure?
carlyle
re read all the past posts that were sent to you and follow all recommendationsThere was an error rendering this rich post.
- 123 Chimneys & Flues
