Rinnai boiler
sjm4
sjm4 Member Posts: 2
I am building a new home and planning on installing radiant heat throughout.  I have been quoted a Rinnai high efficiency wall-mounted gas boiler by our local supply house.  Does anyone have any experience with these boilers?
  • Zman
    Zman Member Posts: 7,611
    Aluminum?
    Does it have an aluminum exchanger? That would be a negative for m.
    Carl
    Albert Einstein
  • sjm4
    stainless steel
    it has a stainless steel plate heat exchanger
  • Jack
    Jack Member Posts: 1,057
    The HX is Stainless.
    Rinnai has a few different combis. The 75 & 110 use a plate HX for DHW. The 175c has a 6 gal indirect and the new Q85 & Q130 Premier's have a 24 gal indirect. What were you quoted?
