condensation
Paul S_3
Member Posts: 1,292
What would cause condensation on the Pvc condensate drain on a air handler...? Thanks Paul S
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
347-692-4777
ASMHVACNYC.COM
Humidity
Cold water inside drain and hot humid air on the outside.0 -
humid
how do you solve that problem if it didn't happen with the system before?...thanks Paul SASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
condensation
Any time you are operating a DX or chillwater coil you will have some condensate if the unit is operating correctly and there is moisture present in the air stream, the higher the relative humidity the more condensate. check your cond. drain line and trap and flush them out if needed, make sure your trap and condensate piping are installed per unit recommendations.There was an error rendering this rich post.
Insulate
Insulate the drain line with Armaflex as you would a suction line.0 -
condensation
Thanks guys....Paul SASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
Best Practice
It is best practice to insulate the condensate drain line for a minimum of ten feet to help eliminate the condensation issues.There was an error rendering this rich post.
- 15.8K Strictly Steam
