condensation
What would cause condensation on the Pvc condensate drain on a air handler...? Thanks Paul S
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
  • Humidity
    Cold water inside drain and hot humid air on the outside.
  • Paul S_3
    Paul S_3 Posts: 1,303
    humid
    how do you solve that problem if it didn't happen with the system before?...thanks Paul S
    347-692-4777
    ASMHVACNYC.COM
  • RJ_4
    RJ_4 Posts: 484
    condensation
    Any time you are operating a DX or chillwater coil you will have some condensate if the unit is operating correctly and there is moisture present in the air stream,  the higher the relative humidity the more condensate.  check your cond. drain line and trap and flush them out if needed, make sure your trap and condensate piping are installed per unit recommendations.
  • Insulate
    Insulate the drain line with Armaflex as you would a suction line.
  • Paul S_3
    condensation
    Thanks guys....Paul S
    347-692-4777
    ASMHVACNYC.COM
  • Best Practice
    It is best practice to insulate the condensate drain line for a minimum of ten feet to help eliminate the condensation issues.
