compressor and wiring - where is oil pressure switch?
elfie
Member Posts: 266
here is photo of compressor and wiring
is it possible to see where oil pressure switch is and connection status?
thanks
thanks
OPS
Trace out the wires from the wiring diagram! Is this the system w/ the broken capillary? Why is the smaller SealTite dangling? This system has a "hi-leg" ?0 -
question
what is the sealtite? and what do you mean by 'hi-leg'?0 -
Elfie
You are getting a bit out of your league here. I would suggest calling in a pro if this is urgent.
If you want to continue in this direction. I would suggest you look into a basic HVAC course at your local community college or trade school.0
- 123 Chimneys & Flues
