Do all LWC's Need
ced48
ced48 Member Posts: 469
moving water to keep them operating without false shut downs?
  • Rich_49
    Rich_49 Member Posts: 2,785
    No
    is there one that needs moving water ?
    732-751-1560
    Rich McGrath 732-581-3833
  • ced48
    I Was Warned
    against putting one in a dead end, even with a vent-bad advise?
  • SWEI
    SWEI Member Posts: 7,348
    It's about system temperature
    so a dead end is not going to read that very well, unless the LWCO has a probe long enough to get back into an active pipe (installed in the end of a tee, typically.)
  • Zman
    Zman Member Posts: 7,611
    The dead end..
    Could also plug up with sediment.
    Albert Einstein
  • rick in Alaska
    rick in Alaska Member Posts: 1,514
    dead end
    The dead end can also have an air pocket that can be hard to get out, which will make the control shut the system down since it is not covered with water.
    My 2 cents anyway.
    Rick
