Do all LWC's Need
ced48
Member Posts: 469
moving water to keep them operating without false shut downs?
No
is there one that needs moving water ?You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
I Was Warned
against putting one in a dead end, even with a vent-bad advise?0 -
It's about system temperature
so a dead end is not going to read that very well, unless the LWCO has a probe long enough to get back into an active pipe (installed in the end of a tee, typically.)0 -
The dead end..
Could also plug up with sediment."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
dead end
The dead end can also have an air pocket that can be hard to get out, which will make the control shut the system down since it is not covered with water.
My 2 cents anyway.
Rick0
