solar heater control
P38ace
Member Posts: 1
I have a Robertshaw Solar Commander ser#385F Sensor Wiring Class 2.
It won't shutoff when the sun sets. I would like to replace it. Where could I go to find a replacement? I believe it is a differential temperature type. It controls the circulation pumps on an indirect heat exchanger.
Sounds like...
You are looking for something like this?
http://tekmarcontrols.com/products/alternative-energy/155.html
You are trying to turn on a circulator when the difference between 2 sensors reaches a certain temperature?
Post a drawing or picture if you need help confirming compatibility.
Albert Einstein0 -
- 50 Industry Classes
