pex or copper in concrete?
tonyk
Member Posts: 12
Hello,
I have a boiler with base board heat. There is a 4 ft. piece of copper pipe which is buried in the the concrete slab in the area under my front door. It has developed a leak and I was wondering if it is better to use Pex or stick with the copper. I will be recovering the pipe with concrete when the leak is repaired.
Also, if I use pex are Shark Bite fittings a good way to connect to the existing copper pipe.
Pex
In concrete is better. All though copper lasts a long time, pex will outlast copper with the use of fly ash, and other chemicals in today's concrete mix its hard on copper.0 -
PEX
PEX is better but for a short run just run the copper pipe inside a rubber hose to keep it off the concrete. That way you don't have to buy any special connectors.0 -
Pex or copper
If I use pex, or copper should I cover it with a hose? or I was thinking about using pipe insulation or some kind of foam wrap to allow for expansion and to insulate it from the concrete0 -
pipe wrap tape
would be fine, insulation would give you a hollow space in the concrete.
Most plumbing and HVAC suppliers have this tape.Bob "hot rod" Rohr
Shark Bites...
May be okay if the copper is clean and not out of round. Personally, I wouldn't do it. I'd go with the appropriate press fittings. Pex moves form thermal expansion and contraction and may cause an issue with the O ring in the long term.
If it were accessible, that would be a different scenario, but considering the possible cost of redoing it, I'd go with a proven method. If you don't have the tools, you may want to hire a pro.
Also, make sure that you use o2 barrier pex. It does make a difference.Bob Boan
Pex & Connections
No buried connections.0 -
Type L copper
If I use copper, I was thinking about using coil that way no joints under concrete. If I go that route, would type L be OK? or would I have to use type K0 -
Use L
L would be just fine.
I remove old leaking piping and install new L copper pipe. I insulate the pipe where it may contact the concrete.0
- 123 Chimneys & Flues
