low water cut-off
PDB2
Member Posts: 29
I want to install a LWCO (none on it now) on my Weil Mclain CGa spark piloted boiler, but unsure as to using a 24v or 120v type. What would I need to be considering to decide which one to order? Any brand recommendation?
lwco
Curious, what boiler/mechanical inspector allowed this install without one.There was an error rendering this rich post.
LWCO
There are plenty of places where LWCO's are not required on residential jobs.
Both 120 volt and 24volt accomplish the same thing. Unless code dictates, use whichever is easier for your install.
Albert Einstein0 -
lwco
that scares me, residential should have the same or tighter code requiements in your areaThere was an error rendering this rich post.
lwco
sorry I meant the same or tighter as commercialThere was an error rendering this rich post.
It depends
Does a mod/com located in a basement need one? You generally have a water pressure safety. Supply and return sensor plus a high limit on the boiler and a T&P.
Is that enough?
Carl
An old school cast Iron is a different animal."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
