Power Gas Conversion Burners
Tim McElwain
Member Posts: 4,657
should they be done away with? It is estimated that 98% of plumbing and heating contractors would not install them. Some interesting rumors about them are:
1. Efficiency only around 70%
2. Gas will rot the oil boiler firebox
3. They require a special stainless steel liner very expensive
4. Most Authorities Having Jurisdiction do not approve them
5. Most boiler manufacturers will void the warranty on the equipment
7. They make very high levels of carbon monoxide
The list goes on, and on and on!
Well I am getting 20 to 30 phone calls/e-mails a week from homeowners looking for someone to install one on their fairly new oil boilers. Anyone interested in this work contact me and give me your location and phone number and I will refer them to you.
Is this similar to
the project MarkS detailed about a week ago?
Why would gas rot an oil firebox?0 -
Voided warranties
doesn't Magnusson-Moss come into play here?0 -
Gotta wonder
who is spreading these rumors.......
And if you get any calls for the Baltimore area, you know where to send them ;-)All Steamed Up, Inc.
Consulting0 -
Burners
I find that the companies who do not install them correctly, and have no idea how to make them run efficiently, perpetuate these rumors so that they can sell entire systems. There is a direct correlation between a technician who bad mouths conversion burners and a technician without a combustion analyzer.0 -
These are some of the
things homeowners are being told when they inquire about converting.
Have also had some mechanical inspectors who state that conversion burners are not authorized unless listed in the I and O manual for the boiler. If not listed then third party testing will be required. They state they have never heard of Z21.8. I am telling installers to refer them to the conversion burner company whose burner they are installing.0 -
I have been told,
not reliably, that MA requires a non universal burner tube. It needs to be a welded air tube for that specific boiler. I have not found this in writing yet. As for liners I often find the people need liners and they need SS because they want the option to go back to oil some day. The chimney needs a liner no matter what burner or boiler is used.Cost is what you spend , value is what you get.
cell # 413-841-6726
as for efficiency being 70%
I have a conversion on a H.B. Smith 101 snowman and I am getting 70% efficiency.Cost is what you spend , value is what you get.
cell # 413-841-6726
conversion burners
Hello,
I've done about 2 dozen Carlin conversion burners in the portland and Midcoast maine area.
My company is Doghouse energy services, located in Freeport Me and I can be reached @ info@doghouseheating.com
Thanks
John Scola0 -
Why
is the efficiency less?0 -
On a snowman
a.k.a. an old round coal-converted boiler, 70% is pretty good. Obviously it would be much better on a newer model.All Steamed Up, Inc.
Consulting0 -
A SS liner
is the only thing to use in a chimney that used to serve a coal- or oil-fired unit. Residual sulfur will eat up an aluminum liner quickly, no matter how well the chimney is cleaned.All Steamed Up, Inc.
Consulting0 -
The efficiency is 70%
because it is a 1910 coal boiler. Kind of a miracle to get that out of it. My point is the newer tighter boilers should do much better than that.Cost is what you spend , value is what you get.
cell # 413-841-6726
Charlie, I have
had some of those in the past with proper baffling and sealing them up real tight with total control over excess air to give 75% and a few dry base with a combustion chamber being built and using an Economite E-20 burner to get 78% and even 80% on a few.0 -
Re CBs and efficiency etc
We have done 100s of CBs over the years since the 1960s. Generally our combustion efficiency will be in excess of 78% and many times over 80. Old pot belly boilers, firetubes, cast iron sectionals etc. Reality is the thermal efficiency is probably only 70% on these pre 1970s boilers. On modern day boilers we do check with the mfr to see if there has been any testing with gas guns. If not we tend to shy away due to liability. We still repair e20s, ds 20s, ds22s, F400s and 800s. Parts have become scarce for the old Economites but we come up with replacement boards through Robertshaw. Always a challenge these days although with mfr support having gone away on the old burners. Just my .02 worth on this subject. Tim0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
