Power Gas Conversion Burners
Tim McElwain
Tim McElwain Member Posts: 4,657
should they be done away with? It is estimated that 98% of plumbing and heating contractors would not install them. Some interesting rumors about them are:
1. Efficiency only around 70%
2. Gas will rot the oil boiler firebox
3. They require a special stainless steel liner very expensive
4. Most Authorities Having Jurisdiction do not approve them
5. Most boiler manufacturers will void the warranty on the equipment
7. They make very high levels of carbon monoxide
The list goes on, and on and on!
Well I am getting 20 to 30 phone calls/e-mails a week from homeowners looking for someone to install one on their fairly new oil boilers. Anyone interested in this work contact me and give me your location and phone number and I will refer them to you.
  • Eastman
    Eastman Member Posts: 951
    Is this similar to
    the project MarkS detailed about a week ago?
    Why would gas rot an oil firebox?
  • SWEI
    SWEI Member Posts: 7,348
    Voided warranties
    doesn't Magnusson-Moss come into play here?
    Steamhead Member Posts: 18,179
    Gotta wonder
    who is spreading these rumors.......
    And if you get any calls for the Baltimore area, you know where to send them ;-)
    Consulting
  • JStar
    JStar Member Posts: 2,752
    Burners
    I find that the companies who do not install them correctly, and have no idea how to make them run efficiently, perpetuate these rumors so that they can sell entire systems. There is a direct correlation between a technician who bad mouths conversion burners and a technician without a combustion analyzer.
  • Tim McElwain
    These are some of the
    things homeowners are being told when they inquire about converting.
    Have also had some mechanical inspectors who state that conversion burners are not authorized unless listed in the I and O manual for the boiler. If not listed then third party testing will be required. They state they have never heard of Z21.8. I am telling installers to refer them to the conversion burner company whose burner they are installing.
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,422
    I have been told,
    not reliably, that MA requires a non universal burner tube. It needs to be a welded air tube for that specific boiler. I have not found this in writing yet. As for liners I often find the people need liners and they need SS because they want the option to go back to oil some day. The chimney needs a liner no matter what burner or boiler is used.
    cell # 413-841-6726
    as for efficiency being 70%
    I have a conversion on a H.B. Smith 101 snowman and I am getting 70% efficiency.
    cell # 413-841-6726
  • jscola
    jscola Member Posts: 4
    conversion burners
    Hello,
    I've done about 2 dozen Carlin conversion burners in the portland and Midcoast maine area.
    My company is Doghouse energy services, located in Freeport Me and I can be reached @ info@doghouseheating.com
    Thanks
    John Scola
  • Eastman
    Why
    is the efficiency less?
    On a snowman
    a.k.a. an old round coal-converted boiler, 70% is pretty good. Obviously it would be much better on a newer model.
    Consulting
    A SS liner
    is the only thing to use in a chimney that used to serve a coal- or oil-fired unit. Residual sulfur will eat up an aluminum liner quickly, no matter how well the chimney is cleaned.
    Consulting
    The efficiency is 70%
    because it is a 1910 coal boiler. Kind of a miracle to get that out of it. My point is the newer tighter boilers should do much better than that.
    cell # 413-841-6726
  • Tim McElwain
    Charlie, I have
    had some of those in the past with proper baffling and sealing them up real tight with total control over excess air to give 75% and a few dry base with a combustion chamber being built and using an Economite E-20 burner to get 78% and even 80% on a few.
  • tim smith
    tim smith Member Posts: 2,886
    Re CBs and efficiency etc
    We have done 100s of CBs over the years since the 1960s. Generally our combustion efficiency will be in excess of 78% and many times over 80. Old pot belly boilers, firetubes, cast iron sectionals etc. Reality is the thermal efficiency is probably only 70% on these pre 1970s boilers.  On modern day boilers we do check with the mfr to see if there has been any testing with gas guns. If not we tend to shy away due to liability. We still repair e20s, ds 20s, ds22s, F400s and 800s. Parts have become scarce for the old Economites but we come up with replacement boards through Robertshaw. Always a challenge these days although with mfr support having gone away on the old burners.  Just my .02 worth on this subject.  Tim
