wet air vents
ben_18
When I took the air vent off the radiator it was wet inside. Does this mean the radiator isn't pitched right?
Do you mean wet
as in drops of water, or wet as in puddles on the floor? If the former, no problem -- it doesn't close until steam hits it, so it's going to have some condensate in it. If the latter, it probably isn't a pitch problem; if it's a problem at all, it may be that the vent is a bit too fast.Br. Jamie, osb
Its just some
moisture. I guess it's not a problem. Thanks.
Any tips on preparing the boiler for the downtime during the summer?There was an error rendering this rich post.
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
- 79 Pipe Deterioration
- 396 Solar
