ok here is the answer early
they had to wait till the outside ambient air got down below 98 with the extreme indoor temp. plus they were not smart enough to take cold water from an outside faucet to keep the head pressure down. Hey this really happened to a very large service company whose name I wont mention.HEY GUYS, IF YOU EVEER GET IN A POSITION WITH EXTREEM HIGH OUTDOOR TEMPS OF 95 DEGREES AND ABOVE ANND IDOORS TEMPS OF ABOVE 86 AND THEY UNIT JUST WILL NOT RUN LOOK AT YOUR PRESSURE CHART. THE HIGH LIMIT WILL KEEP YOU LOCKED OUT.
PEACE BE WITH YOU
DAVID C. BROOME
PEACE BE WITH YOU
DAVID C. BROOME
high ambient
I have run into situations in the past where I would use a water sprinkler next to condensing unit to lower the cond. temp until a could get the indoor heat load downThere was an error rendering this rich post.
I thought I put that in my
answer Dave, 410a is not high ambient friendly.... If its super hot out, I spray them all down no matter what gas they use.. We don't see triple digits often, but changing coil conditions to affect pressures is day one stuff.... Its funny to watch the customers face while you hold there garbage can cover over their fan, it works both ways..0
- 87.1K THE MAIN WALL
- 58 Biomass
- 115 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
- 49 Industry Classes
