Flat plate install
jelly
Member Posts: 3
Pumps on return or supply sides on a flat plate install?
Where's the expansion tank?
Pump away from the tank and all should be well.0 -
Electricity
In addition to "pumping away", I would suggest using zone valves and an ECM circ like the Grundfos Alpha. Your system will use much less electrical energy.
Albert Einstein0
- 109 Chimneys & Flues
- 976 Plumbing
- 387 Solar
- 17 Recall Announcements
