Threaded connections
HOJplumber
HOJplumber Member Posts: 1
I work as a building plumber for The City and County of San Francisco. The Stationary (boiler) Engineers I answer to often have me impersonate a steamfitter (usually to replace valves) and work on steam and hydronic heating lines in the building. For copper tube lines I braze ("silver/hard solder") the connections, but for the threaded connections I use the same Blue Magic or Rectorseal brand pipe dope and teflon tape that I use for potable water. Before manning the plumbing/piping shop at this bulding by myself, I was part of a crew of plumbers and genuine steamfitters who shared a shop (though we had seperate locker rooms as well as seperate supervisors who each answered to the same stationary engineer). When I called my vendor (who have the word steam in their name) to ask what I should use for high heat threaded connections they just say to use Blue Magic, but I remember that the steamfitters used a different kind of pipe dope that was grey in color, so I suspect that their must be pipe dope and tape that is better for steam and hydronic heating lines. I haven't found any answers in "Modern Hydronic Heating" or in Dan's books so I'm asking you. Please tell me what to use for threaded heating piping and components.
Thanks,
  • JaredM
    JaredM Member Posts: 57
    Pipe Dope for Steam
    This subject has been argued by folks for years.  Do some searches on this board and you will find all manners of opinions.
    For steam and water I use single strand wicking and a good quality pipe thread compound.  I usually grab some flavor of teflon based pipe thread compound.
  • RJ_4
    RJ_4 Member Posts: 484
    pipe dope
    For fittings i never want to leak i would use expando or grip.   Our you at the Hall of Justice, I worked for a co. that did alot of work there, i knew Manee , he retired also Knew Renee and Tom.     Retired fitter Rick
  • gennady
    gennady Member Posts: 840
    edited April 2013
    Pro dope
    Pro dope is the best and only tread joint compound right for job.
    http://www.oatey.com/doc/prodope.pdf
  • Cal Steam
    in the Bay Area sells all the usual stuff: Recorseal, Blue Magic, etc.  The grey dope that you mention sounds like a specialty product.
    If I have a difficult connection, say a large, pitted fitting where I have to start my piping or a European fitting that has no taper, I use Super Dope; it works anaerobically.  I've tried it on new fittings with only hand tightening - no leaks!
  • Steve_210
    Steve_210 Member Posts: 664
    Pro dope
    Is gray
    Seems very popular on the east coast
