NOISIEST Burnham Alpine
frankie333
Member Posts: 1
in Gas Heating
Hi folks, this is the first heating season that this Alpine has gone through. I have called an HVAC repair person on multiple occasions. anyway the problem is the neighborhood can hear the system..loudly 2 houses down the street, and of course, in the house it is TRULY horrible when the noise comes on. I tried to record the sound but I can only record the clicking sound the burner makes. HELP anyone, please!!! It sounds like someone is moving furniture. A neighbor thought someone had broken in. Thank you!
call a tech.
You need to get a tech there and do a combustion test, before something happens... obviously not running rite if you can hear it, I have installed alpines and never had one sound how you are explaining it, is this NG or LP?0 -
Combustion analysis
As Heatpro said, Combustion test.
Don't let anyone touch it unless the intend to do a combustion test. You are living with a potentially dangerous situation."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
alpine
Questions
1 When does the noise occur ? On start up I assume..
2 Did it just start or has it gradually got louder?
3 Post a pic of venting….
4 Do you have a copy of installers report on initializing…Did you call him/her back?
5 Is this natural gas and, if so, what is gas pressure,and is main/riser properly sized?
Chances are it is a simple fuel/air adjustment…..If it was installed correctly….
Not installed correctly it could be other issues as well0 -
response
I as other posters on this site truly appear to enjoy it,why else would we…Many of the questions and responses also help us…..I ask when I/we respond you give us feedback,as to what may have helped…..0
- 123 Chimneys & Flues
