Boiler room door
KeithB
Member Posts: 1
My boiler is in a very small closet in a finished basement. I added a direct air intake to the boiler from outside and want to replace the closet door. I have the following questions:
- If I install a wood door, does it need metal flashing on the inside by code?
- what door vent products are recommended to reduce noise?
Thanks in advance for your help.
Keith
Keith
Need to
Ask someone in youe area. The old local codes apply rule is in play.0 -
door
Without knowing where you live, we couldn't tell you what the code is. Give a call to your local department of buildings and ask to speak with an inspector. Usually they're very helpful.
Keith0
- 120 Geothermal
