Need some info.
Harvey Ramer
Member Posts: 2,281
I want to do a Radiant Floor with the sandwitch method. The method used by HeatLink DryAbove system.
I would like to find some charts or formulas to determine water temps needed, based on desired surface temp, tube spacing and floor covering R value. None of my charts give me data for this specific application.
Thank you
Harvey
Thank you
Harvey
Harvey...
... Why not just use the HeatLink design program.... it will provide everything you need... loop lengths, flow rates, pressure drops, manifold settings, etc. you can download from the HeatLink website. Get the older Excel version.... assuming you have MS Excel on your computer. If you can't get it from website let me know. I have it.... been using it for years.Terry O0 -
I did try that.
I have excel 2003 but for some reason I can't get it to work. Comes up with some kind of runtime error when I try to open setup.exe in excel. I did change the security settings to allow the Macros to run.
Not sure what is going on.0 -
Excel
will not open .exe files. Try double-clicking on setup.exe and see what that does.0 -
I did try that.
Same result.0 -
Just looked
and it's an add-in according to http://www.heatlink.com/en/content/design-suite-installation-instructions-excel-2003
I'd call HeatLink and see if they could assist with the install.0 -
I guess I could do that.
I already have umpteen heatloss/design programs. I was kind of hoping someone would know of a mathematical formula that would allow us to figure for any design particulars that come about.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
