Flow Meter Recommendations-
ced48
Member Posts: 469
Any recommendations for a good, inexpensive flow meter?
Flowmeter
What size? What fluid and what's the temperature of the fluid? What is the application?0 -
flow
If you have inline guages, petes plugs or circut setters you can use a pump curve, Bell and Gosset makes system flow documents ( circut setter wheel )There was an error rendering this rich post.
One Inch-
180 degree temp, flow range 1 to10 gpm, - I want to be able to fine tune the flow thru a modcon boiler and simple system loop. I need to have a minimum flow of 3 gpm, and a maximum of 4 gpm- no room for guessing. I am not using primary/secondary piping.0 -
Hedlund
Hedland makes good flowmeters. http://www.hedland.com/
A circuit setter will be needed to adjust the flow.0 -
How About a Caleffi 132 Series?
Sounds like this gut might do both?0 -
minimum and maximum flow
Can't you set this using ∆T with the boiler on high fire?0 -
I Don't See How
I can, unless I am using a variable speed circulator.0 -
Use a circuit setter to...
Do what SWEI is saying. You are going to have to have some sort of balancing or flow adjusting valve anyway. Adjust it until you get the desired delta T.
Caleffi makes the FlowCal device that come in desired flow rates. They probably have a model for 3.5 GPM. It will do the work for you and keep the flow capped at the designed for rate.0 -
Here is one
FlowCal Compact Automatic Flow Balancing Valve 1" NPT Male Connections, Low-Lead Brass
"The Caleffi FlowCal Compact Automatic Flow Balancing Valve has a Flow Capacity of 3.5 GPM."
http://ecomfort.com/flowcal-compact-automatic-flow-balancing-valve-1-npt-male-connections-low-lead-brass-67296.html
They make them in different fitting sizes and types. (Sweat, threaded...)0 -
Caleffi 132 or 127-
Is one more suited for my purposes than the other? I like the fact that the 132 has a gauge.
Do they work the same?0 -
I think
I'd like the 132 better myself as well.0
- 167 Indoor-Air Quality
