Snow Melt Water Temps
Wayco Wayne_2
Member Posts: 2,479
I have a small snowmelt system for our sidewalk out fron. What sort of water temps should I be seeing across the system, supply and return when it is operating during a snowstorm???
It depends...
It really depends on the design. We just did one with 3/4" pex at 9"oc. We used 2" blue board and centered the tubes. It runs really well at about 100-120. I tried it hotter and the heat was uneven. Lower temps also put less thermal stress on the concrete.
Albert Einstein0 -
wow!
I've been running at 90 and was afraid that was too high. I have it set down to 80 as an experiment. I'll let you know how it flys.0 -
temp
90* is the normal design temp for snow melt. Too hot and you will damage the concrete.0 -
good info
I may try it a bit lower."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
