Prestige Excellence goes into hard lock out mode
oak
Member Posts: 22
I have a TT Prestige Excellence that has gone into hard lock out mode three times and each time it is storm related. Last time I came back to 30F indoor temp. After the second time I installed the fix kit supplied by TT: its a time delay that is supposed to respond to power sags or brown out by forcing a restart. A week after we put in the fix, a winter storm with lots of strong wind gusts defeated the re-ignition sequence again and gave the same code: tried to start 5 times and then locked out: code E1.
Two facts:
Boiler cabinet door not on the unit when these hard lock outs occurred
The roof top exhaust vent pipe is cut straight and does not have the recommended 90 degree down turn.
Two facts:
Sounds like
You answered your own question, turn down the roof vent to Manu specs.... And put the door on that thing... And if you are experiencing this much storm related issue I would recommend and aux system of some sort, and some sort of battery powered inverter backup system...0 -
Trimax?
If so, I bet it has nothing to do with weather, merely coincidental.To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Trimax?
Trimax?
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
