Prestige Excellence goes into hard lock out mode
oak
oak Member Posts: 22
I have a TT Prestige Excellence that has gone into hard lock out mode three times and each time it is storm related.  Last time I came back to 30F indoor temp. After the second time I installed the fix kit supplied by TT: its a time delay that is supposed to respond to power sags or brown out by forcing a restart. A week after we put in the fix, a winter storm with lots of strong wind gusts defeated the re-ignition sequence again and gave the same code: tried to start 5 times and then locked out: code E1.
Two facts:
Boiler cabinet door not on the unit when these hard lock outs occurred
The roof top exhaust vent pipe is cut straight and does not have the recommended 90 degree down turn.
  • heatpro02920
    heatpro02920 Member Posts: 991
    edited March 2013
    Sounds like
    You answered your own question, turn down the roof vent to Manu specs.... And put the door on that thing... And if you are experiencing this much storm related issue I would recommend and aux system of some sort, and some sort of battery powered inverter backup system...
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,588
    Trimax?
    If so, I bet it has nothing to do with weather, merely coincidental.
  • Robert O'Brien
    Trimax?
  • Robert O'Brien
    Trimax?
