LWCO/FEEDER ISSUE
TLM
TLM Member Posts: 38
I have a customer w a 7 yr old WM boiler- Hydrolevel 450 lwco and a M/M 101? auto feed. the lwco works when draining the excess water from the boiler. Problem is when I shut the power off to service the burner, the feeder feeds when I turn the power back on, regardless of water level and is overfeeding. I think the LWCO is faulty. Am I wrong?
  • ChrisJ
    ChrisJ Member Posts: 17,075
    Doubt it
    I have not personally had the problem as I hate auto feeders.
    However here is a video of Gerry Gill explaining the issue I beleive you are seeing.
    http://youtu.be/XsAG_cmv2Iw
